Rubber barrier behind door panel?
Old 05-22-2016, 11:18 AM
Joshua_D's Avatar
Joshua_D is on a distinguished road
Default Rubber barrier behind door panel?
So, my driver door is rattling a bit, and it's kind of annoying. I replaced the speakers and discovered that the driver door panel had already been removed once, to fix the power mirror I think. They busted the door handle bolts, of course, and tore off the rubber vapor barrier. So, does anyone know where to buy a replacement vapor barrier, and any tips to quiet the door panel rattle? I've considered just drilling holes and screwing the panel down.
Thanks in advance.
I added a pic. The rubber piece hanging down is what I'm after.
Attached Thumbnails Rubber barrier behind door panel?-dpgjia17a_99_jimmy.jpg
Old 05-22-2016, 12:12 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
I would suggest just using some of that acoustic mat stuff like dynomat. But, I'd buy the cheaper stuff
Old 05-22-2016, 01:30 PM
odat's Avatar
odat is on a distinguished road
I'm sorry but in pic I can't tell for sure but if vape barrier isn't totally dead and you just need a way to attach it back in place, clean the dust off the door and barrier and use gorilla duct tape to rehang it.
most older vehicles the barrier was just a plastic sheet I've even seen paper barriers
As far as rattle goes if the plastic attachment clips are broke most part stores carry them, but if the attachment points are broke on the panel its self you will have to find a different panel in good shape or do the screw idea - been there done that
Old 05-22-2016, 05:58 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Looks like you just need some pins to hold that in place. as for rattling, dynomat or second skin, something along those lines. They can get expensive quickly.
I went the ghetto way when I had my jimmy to stop the rattling and got some of this, stuck it in place and removed the foil. It worked great. Its sturdy foam with 2 sided adhesive.
E/O 12 in. x 15 ft. Self-Stick Foam/Foil Duct Insulation-FV516 - The Home Depot
Old 05-23-2016, 06:18 AM
Joshua_D's Avatar
Thanks fellas. odat, that pic isn't of my blazer. That's just an example of the piece I'm trying to find.
rich, that duct insulation looks promising thanks for the idea.
WalkGood
09-23-2013 12:17 AM
Silock
07-25-2011 03:43 PM
9402blazerky
04-04-2011 11:46 AM
blkblazer
03-03-2010 12:06 PM
02xblazer
01-05-2010 01:58 PM
Quick Reply: Rubber barrier behind door panel?
