security status led
I assume this would be in addition to the SECURITY indicator in the dash, right?
I do not know or have the OEM security system, but I would think that the security module provides the ground or return side to illuminate the SECURITY lite; so if you constructed your LED circuit and connected the return side of this circuit to the wire that goes to the dash connector for the SECURITY lite, it would likely work. I think the OEM security module would be able to handle the small additional current load of a single LED.
You would have to pull the dash apart and trace the wiring as I doubt that you are going to find any information on the OEM security module/wiring. Should be pretty easy to do though.
Good luck.
Good luck.
if your just looking for a visual deterant
Buy one of these and run it to continuous power , install a switch so it doesn't drive you crazy when driving at night
Security Lamp Upgrade Anti Theft CAR Alarm Navy Blue LED Lights Viper Python ARM | eBay
96jimmyslt4x4
05-29-2011 03:55 PM
mritech
02-12-2011 10:38 AM
