Service Engine Soon light... Code P0440
Old Jan 5, 2007 | 09:26 PM
chevyrocksu's Avatar
chevyrocksu is an unknown quantity at this point
Default Service Engine Soon light... Code P0440
Hello i have a 99 blazer 4 door and my service engine light came on, so i had run of my buddies run a scan tool on it and it said P0440 evap emissions control failure. I have no idea what that means... has any one had this code pop up before? thank you
Old Jan 5, 2007 | 09:29 PM
Default RE: Service Engine Soon light... Code P0440
This typically points to a improperly tightened gas cap, faulty gas cap, or over filled gas tank. Did you recently fill up with fuel? When you tighten your gas cap, do you tighten until you hear it click 3 or more times?
Old Jan 5, 2007 | 09:31 PM
I check the gas cap as soon asthe light came on i had that happen b4... I have not filled up with gas for a while, but i noticed when that light came on it sure felt like i was using up more gas.
Old Jan 5, 2007 | 11:51 PM
20Blazer00's Avatar
The evaporative leak detection diagnostic strategy is based on applying a vacuum to the EVAP system and monitoring the vacuum decay rate. The VCM monitors the vacuum level via the fuel tank pressure sensor input. At an appropriate time, the EVAP purge solenoid and the EVAP vent solenoid turn ON, allowing the engine vacuum to draw a small vacuum on the entire evaporative emission system. If a sufficient vacuum level cannot be achieved, a large leak or an EVAP system malfunction is indicated. The following conditions can cause this problem:
[*]A disconnected or malfunctioning fuel tank pressure sensor[*]A missing, malfunctioning, improperly installed, or loose fuel cap[*]A disconnected, damaged, pinched, or blocked EVAP purge line[*]A disconnected or damaged EVAP vent hose[*]A disconnected, damaged, pinched, or blocked fuel tank vapor line[*]A disconnected or malfunctioning EVAP purge solenoid[*]A disconnected or malfunctioning EVAP vent solenoid[*]An open ignition feed circuit to the EVAP vent or purge solenoid[*]A damaged EVAP canister[*]A leaking fuel sender assembly O-ring[*]A leaking fuel tank or fuel filler neck [/ul]
Any of the above conditions can set a DTC P0440.
Old Sep 15, 2007 | 06:18 PM
quinnman105's Avatar
quinnman105 is an unknown quantity at this point
Does anybody know how I can get the Purge/Vent Solenoid? Do you think this will help? This is the same Damn code I've been getting every time.
Old Sep 15, 2007 | 08:35 PM
The vent/purge solenoid is available at your favorite autoparts store. The location depends on whether you have a 2dr or a 4dr. I can't remember the exact location of the 2dr vent/purge solenoid, but on a 4dr, just drop the spare tire if you have it underneith and it'll be in the middle of the crossmember directly behind the rear axle. It'll have one large vacuum line and an electrical connector.
Old Sep 15, 2007 | 09:02 PM
Kyle,
I went to Autozone, Pepboys and Advanced Auto. None of them had them in stock. Not sure if they need to special order it.
Old Sep 15, 2007 | 09:28 PM
Hmm Could have sworn that they were available in the aftermarket. But anyway, its ACDELCO Part # 214633. Shouldn't be more than $20 from your local dealer... That is the purge valve. The purge solenoid is on the engine, but this is rarely the source of a P0440 code.
Old Nov 18, 2007 | 10:26 AM
My truck is running good. No Check Engine Light in about "3 weeks"
Old Nov 18, 2007 | 06:07 PM
hernandez3674's Avatar
hernandez3674 is an unknown quantity at this point
my 97 expericence the same problem after i purchased it.. I didnt realized the pump was changed also. I Changed both the selenoids on the engine and under the spare tire... with no luck.. replaced the fuel pressure sensor on the fuel pump sending unit without dropping the tank and still no luck and of course the gas cap.. I spent last weekend dropping the tank and low and behold the vent valve was broke off at the vacuum line fitting. Since i replaced all the sensors myself i know i stll saved money . Dealer wanted $400 to drop the tank..and replace the valve... $20 for that little problem part at the dealer and about half a day labor but well worth it...Go to rockauto.com... they have the illustrations that will help you.
Brian5792
Sep 13, 2017 07:03 PM
amello1
Jan 2, 2006 01:14 AM
alish199
Sep 29, 2005 12:09 PM
TwilightEpitaph
Aug 11, 2005 01:06 AM
gmyoyo
Engine & Internal
Mar 29, 2005 12:17 PM
