Air pump hose t connector melted
Old 03-18-2013, 11:33 AM
djsgarrett's Avatar
djsgarrett is on a distinguished road
Default Air pump hose t connector melted
2001 Blazer 2wd. Started it up yesterday and heard air rushing out from under the engine. The T-connector that connects the hose coming out of the air pump (under the radiator) to 2 hoses going toward the engine melted. I do not want to replace the T without knowing what caused it to melt in the first place. Any suggestions?
Old 03-18-2013, 04:29 PM
Follow the hose toward the engine and you'll find a check valve, the check valve needs replacement. Buy Wells Vehicle Electronics Air Pump Check Valve E254 at Advance Auto Parts
Old 03-18-2013, 04:42 PM
rexazz2's Avatar
Old 03-18-2013, 04:54 PM
djsgarrett's Avatar
Will do! Thanks! Too bad the T-Connector is a dealer part only.
Old 03-18-2013, 05:00 PM
djsgarrett's Avatar
Yeah, I think there are 2 check valves.
Old 03-18-2013, 06:38 PM
rexazz2's Avatar
you could probably rig up a T at homodepot but probably not worth the time or effort
with the T out it should be easy to figure out which check valve is shot once you start the motor
Nate Chesebro
09-27-2012 09:05 PM
zackmac7
12-13-2011 10:30 PM
jt77
02-05-2011 05:31 PM
Benedict1337
02-05-2010 02:15 PM
blazeitupdrgonzo
12-14-2009 01:01 PM
Quick Reply: Air pump hose t connector melted
