share some useful questiosn and anwsers..
Old 06-16-2011, 04:24 AM
billharryeobd2's Avatar
billharryeobd2 is on a distinguished road
Default share some useful questiosn and anwsers..
Where is the turn signal relay on the 1996 Chevrolet Blazer S-10?
Answer
On 95-97 and possibly 1998, both the turn signal and hazard flashers are located behind the lower dashboard trim just to the left of the cigarette lighter. You can not get to it without taking apart the trim (stupid design). On mine I drilled a 2" diameter hole in the trim with a velcro cover so I would never have to do it again
1999 and later it is under the glove compartment ==Answer= It's behind the panel to the left of the cigarrette lighter. You need a Torx 25 screwdriver and another screwdriver for those hex shaped screws, forgot the size. First unscrew the 2 Torx 25 screws beneath the steering wheel. Then unscrew the rest of those Hex screws on the bottom. The panels overlap, so be prepared for a lot of unscrewing. You do need to unscrew the middle black panel on the bottom, right beneath the cig lighter. It's held by two Hex shaped screws, one on each side and are hard to unscrew. Also you need to remove your spare change sliding tray to unscrew the last hex looking screw. Once you pop your panel off, the turn signal flasher is the right one. The Hazard flasher is the left one. You can find a replacement part at Autozone, and DON'T get the $184 Flasher switch, all you need is the signal flasher. It's shaped like a cylinder with TWO prongs on it.
Old 06-16-2011, 04:25 AM
more ideas welcoem.
Old 06-16-2011, 07:35 AM
TripleBlackBlazer's Avatar
choover82
01-21-2012 12:10 AM
ground_sniper
09-21-2010 07:23 PM
cbr995
04-16-2010 06:22 PM
drperry
03-25-2008 04:15 PM
Quick Reply: share some useful questiosn and anwsers..
