She's Stoped Blowing
Hello all,
Just a quick one hopefully it's obvious..
Anyway my 99 blazer seems to have stopped blowing air, hot or cold..
which is some what of a dilemma where i live as its currently -30 and -50 with wind chill.
may be its full of snow or ice, I'm not sure but it was working fine then tonight nothing..
if any one has any idea of what could be causing it, if it is the weather.. (i doubt it as it has been like that for the last month)
i would really appreciate your help..
blazer noobie
blazer noobie
RE: She's Stoped Blowing
From your description, it sounds as though the blower motor has stopped working. Is this correct?
Do you have the manual climate controls or do you have the automatic?
Does the fan refuse to work on any setting, including HIGH? If so, I would start at the HVAC fuses. There are two, one in the underhood fuse block labelled HVAC which is a 30A fuse and the other is in the IP fuse block (behind the cover on the drivers side end of the dash, visible with the door open, again, labelled HVAC, but this time it is a 20A fuse. The fuse in the underhood fuse block is for HIGH fan operation while the fuse in the IP fuse block deals with all modes and if blown, all modes will off.
If it operates on HIGH, but no other modes, then the problem most likely the blower motor resistor block.
If the fuses check out ok, then you can move to checking the relay in the underhood fuse block. If you exchange it for another one like it and the blower motor works, then the relay is the problem.
If the relay checks out ok, then the problem very well could be a faulty blower motor. You can test the connection to the blower motor for proper voltage with a multimeter. You can also use test leads to put voltage to the blower motor.
Thank you for your quick response...
From your description, it sounds as though the blower motor has stopped working. Is this correct? Yes this sounds correct.
Do you have the manual climate controls or do you have the automatic? well its manual, but also has an auto setting.. if that helps.
RE: Shes Stoped Blowing
Then it is automatic. Check through the things I have listed.
corvair wally
07-19-2011 10:44 PM
Brocktward
06-29-2008 05:29 PM
michellesmark01
Engine & Internal
01-21-2006 07:30 AM
