Should there be a big difference with the MAF plugged in?
Old 02-03-2013, 06:19 PM
stinz's Avatar
stinz is on a distinguished road
Default Should there be a big difference with the MAF plugged in?
For a while my blazer has been sluggish and has had really poor fuel economy (10mpg) so today I took out the MAF and cleaned a bit of crud off of it with canned MAF cleaner, didn't physically touch the sensors themselves.
Reinstalled it and drove around for about 10 mins and then the check engine light came on. I then realized that I didn't plug the MAF back in. So I plugged it back in and now the blazer feels the exact same as it was it was before I cleaned it. With the MAF unplugged it drives pretty much the same.
should there be a big difference in how the vehicle drives with the MAF plugged in vs not plugged in? Now the check engine light wont turn off even with the MAF plugged in.
Old 02-04-2013, 08:22 PM
Blazin00LT's Avatar
Blazin00LT is on a distinguished road
disconnect your battery terminal of your choice and turn on the headlights, let it sit for about 20 minutes. This will fix your check engine lamp.
Old 02-04-2013, 08:26 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
Definitely the negative... disconnect the negative.
Old 02-04-2013, 08:41 PM
Charles Hines's Avatar
Charles Hines is on a distinguished road
The computer uses the last stored data from the maf if it's disconnected,so the engine will probably run ok, but not right under all conditions.
Old 02-05-2013, 12:40 PM
Diaita's Avatar
Diaita will become famous soon enough
I've forgotten to plug my MAF in once or twice, on mine it makes the engine stumble a bit off idle, but runs fine.
shotnva777
09-10-2011 01:14 AM
fast eddy
Performance & Brainstorming
08-01-2010 09:45 AM
mcaanda
05-23-2009 04:04 PM
PHATSPEED7x
Tires and Wheels
05-23-2009 02:09 AM
Quick Reply: Should there be a big difference with the MAF plugged in?
