AT Speed sensor issue
Howdy all,
A friend of mine has a Blazer, that recently had an automatic transmission into the limp mode. The problem was with an AT faulty speed sensor, which was replaced. Luckily the transmission went out of the limp mode, but he noticed, the gears are being shifted at a higher RPMs than usual (i.e. it was 2500rpms before, now is 3500).
His velocity gauge had not been working since long time ago till now, so he cannot refer to the speed.
My idea is that the sensor wasn't installed deep enough, so it is not picking the rpms properly. I gave a call to the person that carried out the replacing job and the guy said, the sensor they got is not the genuine one (made in Taiwan). He says there are no shims for adjusting and dropped me the photo of these two sensors (as per attached).
Looking forward Your opinion.
Cheers, MikeGenuine, old sensor and a replacement
The speed sensor is a set length. If you screw it in farther you'll likely contact the reluctor ring and tear the end off the sensor as the tolerance is fairly close. The speed sensor reads PPM Pulses Per Mile and isn't involved in measuring engine rpm's.
What year are we talking about? Is it 2 or 4wd?
Thanks buddy! You're right, if there is a crap in between teeth, it will not pulse properly. I haven't though of it
Actually I did not Luckily not my ride, but a friend that lives 60miles away. But in regard to Your question - my hint: get a cheap endoscope on ebay and a usb micro plug<->usb-A socket cable and turn Your mobile into a remote camera. It should cost You no more than a $15 bucks.
Pipewrench Dale
11-10-2014 06:16 PM
svd85
11-28-2009 09:10 AM
shutternot
08-03-2005 07:57 PM
