Squeal + Knock
Squeal + Knock
Trying to hunt down this issue im having with my 99 bravada i inherited.
There is a knock and a squeal neither sounding like they are internal but from the belt pulley area. The squeal is definitely not the belt its a metal on metal kind of squeal. The sound does not seem to be coming from top pulleys and i did replace the tensioner. It seems to be coming from around the water, power steering and crank pulleys but i cannot for the life of me tell which one. Not sure if its related but the AC only blows hot air and from what i am told it overheats making me lean towards the water pump.
My wife took a video with her phone that captures the sound pretty well. Keep in mind though i broke a spark plug cable and couldnt get it replaced tonight so its running on 5 cylinders otherwise it idles pretty well besides that awful noise.
https://www.youtube.com/watch?v=4ERw...ature=youtu.be
Any help would be greatly appreciated.
Im unsure on the knock but the squeal is definitely not internal. Its hard to capture the sound in a way that you could hear well.
Finally got around to popping off the timing chain cover and i seem to have found the issue. Looks like the crank snout is bent pretty bad. That would explain it. Now to decide if the things worth rebuilding or putting a new engine in.
