Steering Wheel Play
Steering Wheel Play
When Idrive my steering wheel seem to have a alittle play. I can move it side-to-side and the truck will keep straight. Any suggestions?
RE: Steering Wheel Play
I would get someone to turn the wheel for you while you get under the car and check the tie rod ends, pitman arm and I think Blazers have a rag joint too.
Much of this is due to the steering gear (reciprocating ball) setup. There is an inherent neutral position. But regardless of that, you should definitely inspect the steering components. Idler arm is a good source of play along with the other suggestions above.
And yes, all s-series vehicles have a rag joint.
Yea I forgot to say idler arm I actually replaced mine a couple days ago.
meatchief
04-08-2009 07:04 PM
Kojak
01-23-2008 06:28 PM
