stuck key and shifting issues
Old 07-12-2010, 10:29 PM
campvalley's Avatar
campvalley is on a distinguished road
Default stuck key and shifting issues
Got a 97 blazer 4x4 with floor shifter. I am getting multiple codes P0740 among others and the key will not turn all the way back to release. When driving it will not go into 1st or overdrive. Reading a bunch of posts I see alot of similiar problems. It did have a defective ignition switch harness (pink wire on C5 of the connector had no power) that I replaced with one from a salvage yard. Couldn't really see spending the 100 for one when I could get one for 10. Now I'm thinking this harness is defective but I would love to see a schematic for the parking solenoid but I cannot seem to find one. Any help would be appreciated.
Old 07-12-2010, 10:35 PM
Flatearthman's Avatar
Flatearthman is on a distinguished road
click on the sticky post "helpful threads" one of the posts has a link to download a service manual that should have the info you need
Old 07-12-2010, 10:43 PM
campvalley's Avatar
I must be an idiot. Can't find the sticky post "helpful threads". I would love to download a manual. Could solve all my problems.
Old 07-13-2010, 12:09 AM
it's the fourth sticky thread down on this page
Old 07-15-2010, 08:56 PM
campvalley's Avatar
Just got done fixing the problem. Troubleshot and found 0 volts on the transmission fuse. Should be hot in run position on the ignition switch. Gained access and replaced the ignition harness again. This time with a new one. Didn't really want to spend the $115 for one but didn't want to replace it again either. It fixed the shifting issues, fixed the issue of not being able to turn the key all the way off. Check engine light cleared itself. By the way went to the library and used alldata for schematics.
Old 05-12-2012, 05:35 PM
zr2jay's Avatar
zr2jay is on a distinguished road
Default 2005 zr2 ignition problems
recently my key wont release so i changed ignition thought that was the problem but its not but under my shifter is some black box with a white connecter if i wiggle it it tends to release my key changed the shifter and it still does it does any one know why or how to fix
Old 05-14-2012, 03:46 PM
Ogre762's Avatar
Ogre762 is on a distinguished road
Possibly the park interlock? Sounds like a wire or one of the pins in the connector might be broken. Only way to check is to find which wire is causing the issues (I don't have a schematic in front of me) and fix it.
Old 05-14-2012, 05:37 PM
zr2jay's Avatar
i think it might be one of the wires i went to scrapper and got them from another truck im gona try replacing the white connector when i push down on it it tends to release my keys
Old 05-14-2012, 06:01 PM
4x4blazerguy's Avatar
If I remember correctly. On my 97 the park interlock is controlled through the Brake fuse. I had a short at my trailer plug wires that were stock with the tow package.
Old 05-15-2012, 05:59 AM
zr2jay's Avatar
im gonna feel like such an idiot if i look and find one of my fuses is the problem
Quick Reply: stuck key and shifting issues
