stuck key and shifting issues
Old 05-17-2012, 09:59 PM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
im havin same issue, but if i push the lil button on the the colum by the key. the key moves to lock, but the shift problem would still be there. i reset the pcm (more than once) it will start in 1st gear. mine says a low voltage code was present. i checked all fuses, it has a new ingtion switch, and the neutral safety switch is working, if u dont press on the brake it will not move out of park, so thats workin, ive checked the plug at the trans its tight, checked the pcm plugs they are tight, just hope we can figure this out, please help if u can thanks
Old 05-18-2012, 05:19 AM
zr2jay's Avatar
zr2jay is on a distinguished road
as far asi know mine doesnt have the button under the column mines a 05 zr2 ill have to take cover off to see if there is one. what are pcm plugs ? i now cant get back into acc either
Old 05-20-2012, 07:10 PM
my truck had a old o2 fault code, i replaced the sensor, i havint had the limp home mod come back, yet. pcm plugs is the main plugs on the pcm. still sometimes the key will not rock back to off, so all i do is push in on the lil button and rock the key back at the same time.
Old 07-11-2012, 09:19 PM
up date
figured out that the igntion switch i had bought was not a ac delco so it went bad. cause the trans fuse no to be hot, so i jump it with a 12v igntion wire. work but not rite, so i got a ac delco switch now all is good.
Harley-Man
10-13-2016 10:42 AM
stingray74
03-05-2015 08:27 PM
cdbjr2000
05-05-2013 12:00 PM
dagsler
08-10-2010 08:25 AM
96jimmy4x4in
10-07-2007 09:23 PM
Quick Reply: stuck key and shifting issues
