Things i've tried to eliminate a sporatic miss
Old 02-25-2010, 03:25 PM
BLOND1WD's Avatar
BLOND1WD is an unknown quantity at this point
Default Things i've tried to eliminate a sporatic miss
My miss began after my fuel pump failed. 1997 S10 LT. Has been sporadic for nearly 3 yrs. Have done following:
Fuel filter-WIX (removed and blew out fuel lines in case of blockage)
Plugs-AC Delco
Wires-Belden
Cap-AC Delco
Rotor-Echlin
MAF sensor-AC Delco
EGR valve-AC Delco (Gasket w/screen)
Fuel inj. spider-AC Delco
Burnt Exh. Valve-Melling
Distributor-Rich Porter New
ECM-AC Delco
TPS Sensor-Echlin
Catalytic Converter-Hollowed out
Am no longer getting any codes. Still misses.....oddly enough seems only in wet weather. About to turn 180.000. Runs great 89% of the time!
Hope this helps someone, and if you have any ideas, Hit me up!
redroc87
05-29-2012 11:09 AM
travisrussell88
10-20-2011 10:16 PM
scott_wheels
01-26-2010 05:49 PM
GMdesigner
06-22-2007 11:43 AM
Benado
08-30-2006 12:05 AM
Quick Reply: Things i've tried to eliminate a sporatic miss
