what is this part
Old 11-24-2008, 09:45 PM
blazer4x4's Avatar
blazer4x4 is an unknown quantity at this point
Default what is this part
what is this part called i tried getting it today at auto zone and they didnt know what it was . It is for the vacuum of the 4x4 it is on the firewall. They told me i had to go to the dealer to get it I was hoping i could get it at auto zone or napa.
Old 11-25-2008, 05:45 AM
vadatara2's Avatar
vadatara2 is an unknown quantity at this point
Default RE: what is this part
Vaccume control module. I had to get mine at the dealer, about $45.00
Old 11-25-2008, 06:24 AM
4wd Vacuum Solenoid. Electric Vacuum Switch. And probably many more names. The parts stores do not have this component for the most part. The only place I have seen it is the dealer.
Old 11-25-2008, 07:20 AM
blazer4x4's Avatar
do you think this will fix my 4x4 issue. I all ready replace the part under the battery tray and the light still just blinks repeadely after pushing but it doesnt go back to 2 just blinks. After i bought the new part under the battery tray i heard a hissing coming from this part i mentioned. I hope this fixes the problem. Thanks
Old 11-25-2008, 07:55 AM
You can test that part very easily. It is just a solenoid valve. It should be normally sealed and open up when +12V is applied. If you heard hissing, is the part cracked anywhere?
As far as your blinking light problem, I will respond to the other thread you have on the subject. There are a lot of 4wd threads floating around right now. I really wish I had time to consolidate all of the information I have typed out numerous times into a single DIY post, but...
Old 11-25-2008, 09:52 AM
blazer4x4's Avatar
the hissing is coming from the top of the part there is like a breather hole amd if i put my thumb over it the acutator under the battery tray hold pressure, So i was thinking it was a vacuum issue not an electrial issue. the vacuum hoses are good.
spider21
11-17-2011 06:27 PM
zynnad
01-14-2010 04:29 PM
biniecki
01-07-2010 02:07 PM
joeparker1968
02-14-2005 06:44 PM
nerve_agent
10-20-2004 04:21 AM
Quick Reply: what is this part
