Transmission toast?
So I noticed after I put my 96 sl back on the road, that the trans had a bit of delayed engagement. Checked the fluid, it was fine. Was running fine for. Couple of weeks.
Today heading home and I slowly lost acceleration till I pulled over and put it park. then was smoking from the trans and sounded like shot Bearings. I wasn't far from home so tried to drive like 10kph, I had no gears. After being fine for 2 weeks this all of a sudden happens. I re checked the fluid and phew it did not smell good |
I'm no transmission expert, but sounds like it's time for a rebuild, to me
I would agree, sounds like the Tranny is shot... This past summer my Tranny kicked the bucket, lost high gear, could only run about 30mph. My local shop wanted $800 to rebuild it but I found a used 1 in a junk yard for $300 and saved a bunch of money...
Originally Posted by go chevy
(Post 702931)
Luckily, my massive leak was just the cooler lines, and not the front seal like I thought. R&R to replaced the seal was $600, and I figured if it's out, might as well have it rebuilt. |
Originally Posted by cleburne red
(Post 702933)
That's really cheap for a rebuild. Shops around me were wanting $1400 to rebuild mine.
4L60E rebuild.
How hard is it to rebuild one. I have mechanical knowledge just not with transmissions
(Post 702936)
Where I live things are much cheaper compared to the rest of the country from what I see on here lol! I knew I was "rolling the dice" on the junk yard Tranny, but so far it has acted like a champ... It did come with a 30 day warranty, oh joy :)
(Post 702941)
Since you got the old one out, might as well try your hand at rebuilding it yourself!
(Post 702945)
Had to use the old one as a core... Plus I am no where near the mechanic you are and most of the others on here :) Simple things, plugs and wires, oil change, replacing a burnt out bulb ect... I am "king of the world" lollllll.........
And I'm no mechanic by any means lol. I just have a good collection of tools, and the mindset of "it's already broke, can't make it any worse!" Seriously, diagnosing is the hard part. After that, it's just turning wrenches and swapping parts out. |
Originally Posted by peenar
(Post 702939)
