TRZ Motorsports control arms
Anyone tried these out? the look like quality stuff and TRZ makes top notch products, so I suspect they are, also.
Upper and Lower Control Arms (Stock Spring) -
Product Description
Includes:
Product Description
Includes:
- 2 Upper Control Arms, 2 Lower Control Arms, Assembled with Balljoints and
- Control Arm Bushings, and 2 Limiter Bolts.
- Built-in 7 Degrees of Positive Caster
- Designed to Replace Stock Control Arms with No Modifications
- Reduces Weight by up to 15lbs Per Side
- Uses a Stock Spring and Shock or the QA1 PRO-Coil System
- Uppers Come with Limiters in Place to Control Front Suspension Travel
- Designed for Drag Race Applications Where Spindle Caster Can Range from 0 to 10 Degrees
The bottoms look like they might lower the ride hight. That and extra caster is something we need. Can they come without thr ball joints cause I want the tall ones? Wonder did the extra caster come from the top or bottom arm?
Yooper
07-26-2009 03:01 PM
warhammer44
Suspension Tech
10-28-2008 10:56 PM
