Turn Popping/binding in 2wd
Old 12-14-2012, 08:54 PM
coolasice's Avatar
coolasice will become famous soon enough
Default Turn Popping/binding in 2wd
ok, for the sake of not hijacking the "Reverse Turn Clunk Thread" I am posting regarding my popping/binding problems.
Symptoms:
Low speed hard right turns - front right wheel seems to bind up and pop with the occasional shimmy of the tire sliding to the right (sort of like when in 4wd but it happens in 2wd) shimmy not always followed/preceded by pop/bind
Here is what is ruled out so far:
CV Shaft
UCA Bushings
Any thoughts?
Old 12-14-2012, 08:58 PM
Are the stops lubed on the lower control arms?
Is the right front axle disengaging in 2WD?
Old 12-14-2012, 09:11 PM
coolasice's Avatar
1: will be in the morning (even with the -5 wind chill)
2:should be, I can turn wheels independently of each other (I did just recently replace the t-case vac switch and some vacuum lines), will double check though
Old 12-15-2012, 07:48 AM
Raise only the right front wheel, in 2WD it should spin freely, engine at idle, transmission in park.
Old 12-15-2012, 10:24 AM
coolasice's Avatar
not engaged, i did grease the stops, but have not had a chance to test in a clear parking lot (can't do it at home)
Old 12-15-2012, 03:10 PM
Cool, at least we know the front axle is not engaged causing it to bind up. Hopefully greasing the stops will take care of it. Post your results
Old 12-16-2012, 04:20 PM
Toby Hanson's Avatar
Toby Hanson will become famous soon enough
Please keep posting the progress on your issue. I'm watching with great interest as I sort out my own reverse turn clunk.
Old 12-16-2012, 05:55 PM
coolasice's Avatar
I did not have a chance to test yet, but will attempt in the morning (have to find a clear open parking lot to try in.
Old 12-17-2012, 08:07 AM
coolasice's Avatar
Tested this morning, popping was not noticeable, but the shimmying while turning is still there, I am going to say LCA bushings causing this shimmy, they are cracked but not failed yet, will be doing LCA bushings, torsion mounts, and sway bar bushings all this spring
Old 12-17-2012, 04:45 PM
Did you look at the upper control arm bushings too? I had to replace the uppers on my 98 this past Summer.
Quick Reply: Turn Popping/binding in 2wd
