urgent: 2001 blazer problems. (fueling)
ok heres a brief breakdown: did a motor swap on a blazer due to blown motor, the car is not getting fuel for some reason....when we bought the new motor it was off a 2000 gmc jimmy (same motor, 4.3 v6 vortec) . we did not however receive the PCM/computer that comes with that motor. now the car tries to turn over but will not stay on due to lack of fuel. i think its the computer because its off of a different car because when i pour gas into the throttle body it turns on and dies out as soon as it runs out of gas
any ideas?? does chevy reprogram PCM's ??? if not do u know where i can get this reprogrammed with the new VIN?!?
RE: urgent: 2001 blazer problems. (fueling)
Check that your wires are connected to all the sensors, like the oil pressure sensor.
Do you hear the fuel pump run for a few seconds when you turn the key on before you crank it over?
The PCM does not care that the motor is out of a 2000. I do not believe that they changed anything (sensor wise) between 2000 & 2001.
I would verify that you are getting power to the fuel pump. You should be able to pull the fuel pump relay and jumper it as a check to see if you can start it then.
Here's my 2 cents worth related to fuel pump power: My Haynes manual makes reference to a connector on the drivers side of the engine compartment (its a single RED wire with a spade connector) that runs directly to the fuel pump. You can apply 12 V direct to the fuel pump to check if your pump actually works. I searched my engine compartment and actually found the little bugger near where the vacuum ball resides for the cruise control. When I changed my fuel pump I had to drain the fuel tank first (Of course I had just filled the tank a few days earlier), so I put my thinking cap on and used the fuel pump (weak as it was) to drain the tank. I disconnected the main fuel line from the pump, put a long piece of vacuum tubing on the pump connector, put the end of the hose into a 5 gallon bucket and hooked 12V directly to the connector in the engine compartment. The pump fired up and pumped all the gas out of the tank (15 gallons worth). FYI: You cannot use a siphon on a Blazer. There is a ball check in the filler tube which prevents a siphon from getting in to the tank (discovered this when I disconnected the filler pipe from the rubber tank coupling and wondered why there was a little green ball in the end of the filler tube).
snakey
05-12-2012 11:49 AM
Caribbean_Comanche
11-16-2011 12:23 AM
burak sozer
06-21-2008 03:32 AM
neogeo92
04-28-2006 10:51 AM
