2nd Gen S-series (1995-2005) Tech Discuss 2nd generation s-series (1995-2005) general tech topics here.
Weird starter issues, whining and back fire like sound
Old 04-12-2007, 04:32 PM
schnitzer00 is an unknown quantity at this point
Default Weird starter issues, whining and back fire like sound
New owner of a 97 Blazer with 130K on the mileage, got from a family member w/c he bought new. Bear with me on describing the issue, the whole starter was replaced 5 months ago now I have this weird starter issues, the truck starts basically ok but when the engine starts running you could hear this like backfiring sound on the starter area, checked on the engine itself the engine purring like a cat no misfiring or rough idle, when you turn off the ignition you could hear this loud whining or dynamosound on the starter itself w/c itstogauge it1 to 10 it's 7. It doesn't stop until you remove the battery connection and smells like burned thing after, when you start it again it starts normally but then again the whining sound and misfiring like sound.Any advice would be greatly appreciated. Thanks in advance!
Old 04-12-2007, 07:36 PM
Default RE: Weird starter issues, whining and back fire like sound
Since you did not replace the starter yourself take it back to the person/shop who did. It might not be properly adjusted/shimmed, causing the starter drive to not compeletly disengage from the flywheel/flexplate. If this goes on for a long time then you will have to drop the tranny and replace the flywheel/flexplate and get new starter since the starter drive gear would be destroyed by excessive RPM's...
Old 04-12-2007, 07:53 PM
I think that's the logical thing to do bring it back. Just for curiosity if the starter then wasn't properly adjusted or shimmed would it be the problem existed sooner? This just happened yesterday so when we heard the sound parked the truck and didn't use it so not to cause more damage.
moztek
12-22-2011 06:22 AM
tall_ish
11-20-2010 09:05 PM
bigfish
01-16-2010 05:14 PM
gERgMan
09-06-2008 07:27 PM
schnitzer00
04-17-2007 04:54 AM
Quick Reply: Weird starter issues, whining and back fire like sound
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
