Oil Cooler Lines???
Oil Cooler Lines???
I hate to start another post on this issues but I have had no luck getting an answer on the original post. I think that is why I see others doing this same thing because I have no idea how to flag the original post with an up date or a way to let others know I have another question.
Anyway, has anyone had, heard or know of a oil cooler line blowing off the fitting? The hose is not mushy but appears to be leaking, & has been leaking for sometime. The hoses that are giving me problems are the hoses from the engine to the oil filter. I think they are a Dorman #625-001. The reason I ask is I had a Lumina with the same crimp fittings on the A/T & I had one blow off going down the road, but it was real mushy.
Second, how hard is it to change out these hoses? I need to pull the front skid plate off & power wash everything good. Is it real hard to get to the engine block where the hoses connect.
I ask these because it is real cold here & I need a semi warm day before I go trying to wash stuff down & crawl under it.
Thanks in advance
Thanks in advance
Just post into it again if you've waited ~24hrs... No reason to violate the rules of the forum.
BTW, this has all been covered in other posts with some pretty good detail.
Those wishing to reply can do so in the ORIGINAL THREAD on this topic.
*Thread Closed*
*Thread Closed*
fslobodecki@yahoo.com
04-15-2011 03:29 PM
subarugt06
03-06-2011 11:21 AM
