WET WEATHER HESITATION
Old 11-29-2006, 02:22 PM
MRDCSE's Avatar
MRDCSE is an unknown quantity at this point
Default WET WEATHER HESITATION
HELLO ALL, second post. Two months ago purchased a 1996 4 dr blazer w/4.3 with 77k. Truck runs great except when it has rained or is raining. Truck hesitates and is sluggish, servive vehicle light comes on also. Have some mechanical experience, so probably electrical, the wires? If I replace should I also go whole 9 yards and due complete tuneup (at mechanics). Appreciate all replies. Thanks
Old 11-29-2006, 02:36 PM
88s10Blazer's Avatar
88s10Blazer is an unknown quantity at this point
Default RE: WET WEATHER HESITATION
My blazer has the same problem when 1 hit puddles. Its an exposed wire somwhere... I don't know where.
Old 11-29-2006, 02:58 PM
It is also quite possible you have a cracked distributor cap. If moisture is present in the cap, it will cause the spark to scatter instead of being directed into the wire, causing the misfire/stumble you are experiencing. A good tune up consisting of plugs, wires, cap & rotor should be done if you don't have records of when it was last done... Faulty plug wires can leak spark as well. If you want to check the wires, go outside when its dark. Fill an old, thuroughly cleaned out spray bottle with tap water, and mist it over the engine, specifically trying to wet down the wires and their surroundings. If you see sparks jump, you know what you have to do.
Old 11-29-2006, 04:06 PM
nofear17bmx is an unknown quantity at this point
I work on atvs almost every day and a known problem concerning your situation would be a cracked intake tube or an excessive amount of moisture getting in the air box.
Old 11-30-2006, 12:21 AM
DetroitMuscle is an unknown quantity at this point
Check the coil wire. That was my problem.
Scarakus
02-07-2013 12:11 AM
Empire932
10-23-2012 07:08 AM
posetha
01-05-2009 08:41 AM
Mike124
12-08-2007 01:20 PM
user 1016
14
03-21-2007 01:17 AM
Quick Reply: WET WEATHER HESITATION
