What is this thing?
What is this thing?
Hey guys.
So question. I'm currently reassembling my engine, and there's a cable/hose/cord of some sort that I can't figure out its purpose?
It goes beneath the the engine at the driver's side, runs briefly next to the oil lines, and then turns near a bracket that holds the oil lines in place. From there it enters what looks to be a sort of wire loom, and towards the driver's wheel well. However, I cannot for the life of me find it's other end.
I took a pic of it. Anyone know what it is?
Huh. That would make sense actually. Hadn't thought of it being a vent tube. Any reason why it's capped off though? And is there a particular place it should be sitting or a clip it should be hooked into to hold it up?
Cap portion should turn/spin. There is plastic hoop dealie that fastens it to the the inner side of the main fender, between abs and front headlight. They break easy, mine's ziptied.
The cap movement I assume allows for venting.
DARK1
08-13-2018 12:08 PM
