What's wrong if you can rock a front wheel back and forth?
Old 08-28-2010, 09:21 AM
jmaynard's Avatar
jmaynard is on a distinguished road
Default What's wrong if you can rock a front wheel back and forth?
While I was taking my front wheels off to work on the spark plugs, I grabbed the right-side wheel with it off the ground and was able to rock it in and out (hands at 9 and 3 o'clock, pushing and pulling) a bit. The left wheel didn't do that. Which expensive part do I need to replace?
Old 08-28-2010, 09:27 AM
m3ch's Avatar
m3ch is on a distinguished road
You know mine does that too I think...I was thinking I needed an alignment
Old 08-28-2010, 02:24 PM
abig84's Avatar
best bet is to have someone look underneath while you do that. i know the idler arms go bad alot on these things. could be a tie rod too
Old 08-28-2010, 02:31 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
it could be your pitman arm, idler arm or inner/outter tie rods. you should remove the front skid plate and have someone move the wheel like you did and look at those parts, if you see movement then you have a worn part. but also grab the wheel at 12 and 6 o'clock and try moving it that way, if you can move it both ways (left/right and up/down then you have a loose wheel hub/bearing.
Old 08-28-2010, 02:44 PM
jmaynard's Avatar
I did try the vertical rock as you suggested, and it wouldn't budge. Sounds like steering, then. The ball joint on the left was replaced just before I got it; I'm guessing the one on the right needs it, too. There's play in the steering, and I've been meaning to take it in and have it looked at anyway
Old 08-28-2010, 02:51 PM
yea, almost forgot, could be balljoints also.
Old 08-28-2010, 03:07 PM
speterson1011's Avatar
speterson1011 is an unknown quantity at this point
I had the same problem before I lifted my blazer. It was the upper a frame bushings. If you look at them you can tell right away if its them or not. Also my ball joints needed to be replaced, once I did that I was able to get an alignment and the ride quality was back to normal. The ball joints were 15 bucks at autozone and the upper a frame bushings were 5 bucks each. I would say thats what your problem is
Old 08-28-2010, 03:56 PM
NVANZEE's Avatar
Ball joint would have play in and out holding it a 12 and 6. To check the ball joints you have to jack it up by the control arm to keep the suspension compressed. You can tell if they are bad if the suspension is hanging
er0ck273
09-01-2013 11:45 AM
brudel1
04-04-2011 12:00 PM
soundguy
09-20-2007 03:23 PM
98blazergal
11-05-2006 01:49 AM
beilharzc
03-12-2006 01:50 AM
Quick Reply: What's wrong if you can rock a front wheel back and forth?
