Wheel Stud
Wheel Stud
So...I went to test out 4hi and 4lo...got stuck...got pulled out...caused all sorts of mud to get pushed up into the front wheel. It was so bad rocks were squealing on my rotor the whole way home[:@]
So I got home, took the wheel off, cleaned it out (I think I might have a stuck caliper...but that's another thread)..and went to put the tire back on. 4 lug nuts went on fine, the 5th binded up halfway down the stud. So I tried backing it off...no go...pushed it further...no luck..so I forced it back off. I figured I'd just use a new lug (I've got a few spare lugs). Never did I think THAT THE ENTIRE WHEEL STUD WOULD SNAP.
So...The question is..how safe is this for a day or two? The other 4 lugs went on nicely, and are torqued down nice n tight. Also, what causes the stud to break? Obviously I put too much force on the binding threads and it snapped...but is that just normal wear after 100k miles or is that more likely 100k miles of overtorqued lugs?
RE: Wheel Stud
For a bit, yes, but get it replaced ASAP!!
RE: Wheel Stud
Phew...I'll see if I can tip the guys in the installation bay to put in a new wheel stud for me while I'm at work tomorrow
Wheel studs pass for car audio right?
Better question: What all is involved in replacing the stud...is it integrated with the wheel bearing? Or can I go to Napa and buy a couple studs?
RE: Wheel Stud
More pics of muddy truck please
Silver00LT
03-06-2011 07:23 PM
