Where do I find the Ignition Control Module?
The ICM (ignition control module) is mounted to the same bracket as the coil. The bracket mounts to the lower intake manifold right near the distributor. It will have a heat sink attached to it.
You simply unbolt it. Most autoparts stores can test this to confirm that it is the source of your issue. I assume you have an issue that you are attributing to your ICM... Remember to pick up some thermal paste to improve the thermal conduction between the ICM and it's heatsink when you put it back together. New ICM's should come with some thermal paste.
Brian5792
10-24-2018 11:34 AM
chris015
05-22-2009 10:39 AM
cannibal440
Performance & Brainstorming
03-18-2008 10:47 AM
USMaverick101
10-31-2006 03:10 AM
USMaverick101
10-29-2006 10:29 AM
