96 blazer fuel vent valve leaking
Old 05-16-2017, 12:32 AM
96blazer4wd's Avatar
96blazer4wd is on a distinguished road
Default 96 blazer fuel vent valve leaking
I have a 96 blazer 4 door 4wd. I replaced the fuel tank,filler neck,fuel lines from the fuel pump to the fuel filter an put a new vent valve that goes on top of the tank at the front. It's started leaking at the front of the tank around the vent valve so i tried turning it tighter but ended up snapping it got a new vent valve an put it on but it is still leaking around it. Am I just not turning it into place right or something. I'm tired of laying on the ground an frustrated lol. Any help will be appreciated thanks
Old 05-17-2017, 11:53 PM
Another question is should there be any fuel going through the vent valve in to the line that's connected to it going back to the charcoal canister
Old 05-19-2017, 12:16 PM
FMB42's Avatar
FMB42 is on a distinguished road
Hi 96, there should be no fuel in the EVAP system under normal operation. Vapors yes, outright fuel; no. Over-filling the tank and/or parking on a steep downhill incline can, of course, cause this issue due to the design/shape of the tank.
That said; first make sure that you have the correct vent valve and o-ring (I think there are more than 1 type used according to the exact year and model (4 or 2wd, number doors, etc). And yes, these valves can be a bit difficult to get at with the tank installed. Just make sure to thoroughly clean and then lightly oil the o-ring, valve, and tank area and then carefully seat the valve fully into place before you lock it down. A small hand held mirror can help with doing so.
Ja95blazer
04-06-2017 06:54 PM
cmaddox421
12-29-2013 08:33 PM
jfrust64
07-24-2012 08:00 AM
Rider
02-27-2012 03:28 AM
trishharris
14
05-30-2011 12:25 PM
Quick Reply: 96 blazer fuel vent valve leaking
