Will a motor out of a 1990 GMC sierra fit a 97 jimmy?
they are both 4.3L the sierra one though is non - vortec while the 97 jimmy is a vortec.
Any way they would work?
There are A LOT of differences. The largest of which being the presence of a balance shaft in the '97 motor and the lack there of in the '90 motor. The blocks will be somewhat similar, but you would have to swap over A LOT of parts to make it compatible. Your best bet is to find a '96+ engine to use. If you get a 98+ engine, you will have to use the lower intake from your '97 motor as the 98+ engines do not have the temp sensor in the water neck near the thermostat.
fishing fanatic
07-07-2013 09:28 PM
malcolmorams
02-02-2012 11:29 PM
malcolmorams
09-15-2011 09:43 PM
malcolmorams
09-10-2011 02:32 PM
