Go Back  Blazer Forum - Chevy Blazer Forums > Mechanical & Maintenance > General Tech Help > 2nd Gen S-series (1995-2005) Tech
Reload this Page >
wipers, A/C blower, gas gauge, temp. gauge, 4X4 selector and the transmission select
2nd Gen S-series (1995-2005) Tech Discuss 2nd generation s-series (1995-2005) general tech topics here.
Old 07-01-2013, 07:10 AM
grayman63 is on a distinguished road
Angry wipers, A/C blower, gas gauge, temp. gauge, 4X4 selector and the transmission select
Good day, I have been trying to get to the bottom of this issue and I hope somebody out there can give me some info. On my '98 Blazer all of a sudden the wipers, A/C blower, gas gauge, temp. gauge, 4X4 selector and the transmission selection indicator have stopped working. The rig is in nice shape and I have just put a fair amount of repair in to the front end, I really don't want to scrap it but I will need the blower this winter. Anybody know what's up?
Old 07-01-2013, 07:24 AM
rexmburns's Avatar
rexmburns has a spectacular aura aboutrexmburns has a spectacular aura aboutrexmburns has a spectacular aura about
Id start by checking all of the fuses.
Old 07-01-2013, 08:44 AM
Guess I should elaborate. I have already checked all fuses, even changed the ignition switch, somebody before me really butchered the wiring from it.
Thx for your response.
Old 07-01-2013, 11:53 AM
4X4GS10B is on a distinguished road
I would suggest looking over wiring schematics. It can take awile but theymay all share a common wire. Just a suggestion.
Old 07-01-2013, 12:34 PM
spittybays
Guest
Posts: n/a
I think the schematics you should look at will be called "ground distribution circuit" should be like four pages. I have them for my 95 but nit yours.
Sorry.
Old 07-01-2013, 04:49 PM
The ignition switch and grounds are both good possibilities. However, all of the things that are inoperative don't use the same ground, but they may use the same feed through the ignition switch. There are 3 voltage feeds, (hot at all times) to the ignition switch: 2 red wires and 1 orange wire. They are all in the same connector at the ignition switch and feed several different circuits when the switch is turned. Each of those circuits feed separate fuses both in the underhood and the instrument fuse panels. There could be a poor or open circuit in one of those feed wires going to or from the ignition switch. You'll need to back probe each wire in the ignition switch connector, in each position, (start, run, crank, acc) to verify if this is the problem. Pay close attention to: pink, white, brown and the orange wires, yup, two orange wires, one is hot at all times, the other should be hot only in the RUN position.
Old 07-17-2013, 01:56 PM
For those that encounter the same issue, my problem turned out to be a broken wire under the fuse panel in the engine compartment.
Irish07
10-12-2012 04:19 PM
WTuck462
1st Gen S-series (1983-1994) Tech
03-21-2011 02:06 PM
zakm0n
01-09-2011 07:31 PM
Jonas
08-09-2010 06:29 PM
SWATPARAMEDIC
01-01-2010 03:12 PM
Quick Reply: wipers, A/C blower, gas gauge, temp. gauge, 4X4 selector and the transmission select
Advertising
Featured Sponsors
Vendor Directory
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
