Zr2 spare tire carrier fix
Old 01-14-2019, 11:52 AM
nomoresubies's Avatar
nomoresubies is on a distinguished road
Tried to find the OEM bushings via the part #s on the diagram that Christine linked to but it is an obsolete part and no luck on all the usual sites...
  #22
Old 01-14-2019, 03:20 PM
man0steel's Avatar
man0steel is on a distinguished road
Don't think the OE bushing is available anywhere by part number......many have tried and failed. I felt sure I could find it thru aftermarket manufactures but kept running into bronze so just went that way.
  #23
Old 01-14-2019, 07:45 PM
OK so you actually found replacements in bronze or had them made? If you found replacements could you give me a link or a name?
  #24
Old 01-14-2019, 07:47 PM
As part of me wanting to see the condition of the stock bushings for the spare tire carrier I have yet to install, I removed the pin for the bottom hinge. There is a C-clip retainer that fits into a groove on the bottom of the pin but the I had to use a hammer and a drift to push it out from the bottom. Here is a picture of the final result:
Turns out my C clips are long gone which is why I was confused in the removal process. Got the top one loose by pounding with a hand sledge but the bottom one may be a bear...
  #25
Old 01-14-2019, 08:16 PM
christine_208 will become famous soon enough
Since I had my hinge apart, I realized that since the bushings looked in pretty good shape that I had a good opportunity to remove one and take some measurements.
So as to make the post easier to find in the future by others, I created a new thread. Here is the link to it: https://blazerforum.com/forum/paint-...16/#post701431
But for your convenience, here is the text of that post:
Measured dimensions of bushing, GM pn 12546658:
The hole into which the bearing is inserted has an ID of about 0.764" +/- 0.005"
The OD of the pin is 0.619"+/-0.001"
These are the dimensions of the bushing as measured in inches, mm and the approximate nominal fractions of an inch.
ID: 0.632"+/-0.004" (16.05 mm+/-0.10 mm) ~5/8"
OD: 0.775"+/-0.001" (19.69 mm+/-0.03 mm) ~3/4"
L: 0.569"+/-0.003" (14.45 mm+/-0.08 mm) ~ 9/16"
FD: 1.245"+/-0.004" (31.62 mm+/-0.10 mm) ~1 1/4"
FT: 0.057"+/-0.002" (1.45 mm+/-0.05 mm) ~1/16
  #26
Old 01-25-2019, 08:53 PM
Can't pound out the bottom stud; Bad angle. Top one loose. Considering taking off the body mount portion. Will the nuts within the body panel drop into the body or are they tacked on? One of the Torx heads is stripped out so it also leads me to believe they ain't gonna come out easy
  #27
Old 01-26-2019, 12:50 PM
Pretty sure on the vehicles that came stock with the tire carriers, the bolts are held in place on the inside of the panel. I would go with removing the carrier.
Here is a link I found when trying to research this myself.
Spare Tire Carrier
  #28
Old 01-26-2019, 02:33 PM
One can only hope.
Thanks for the photo...
kmenc67
03-25-2019 06:31 PM
Jakek
11-22-2018 04:25 PM
zburger316
Tires and Wheels
06-03-2012 04:34 AM
kinter614
11-12-2010 09:09 PM
jdcool4
08-16-2010 09:08 PM
Quick Reply: Zr2 spare tire carrier fix
