ZR2 wheels
ZR2 wheels
Does the 2wd and 4wd use the same wheels. Are the ZR2 wheels different from the LS? I'm in the market for another set of wheels for seasonal use. I can score a full set at the u-pull-it yard at a decent price but cant return them if they don't fit. Any insight would be appreciated.
Don is right, the 2wd have a different offset, so they stick out on 4x4s.
ZR2, ZR5, LT, and LS rims will all fit on each other fine.
The only thing to look for is the ZR2 normally has 31" tires that won't fit on a stock blazer/pickup without rubbing.
Kind of looks like you have the newest style ZR2 rims on your rig already..
I just picked up an old set of the aluminum Blazer wheels for $25 each and stripped, cleaned and re-sprayed a lacquer coat on them. Wrapped them in the BF Goodrich all terrain KO's 31x10.50x15's.
Rides like a dream with the new tires.
And yes, I removed the spare tire carrier from the back and found an inside mount at a junk yard for $15. Found an all matching black tail gate for $75 that does not have the bracket on it as well.
calee4nyaboy
Tires and Wheels
03-08-2012 04:35 AM
