-   -   01 Blazer Wiper Blade Issue (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/01-blazer-wiper-blade-issue-42096/)
jpmccr 03-12-2010 12:22 PM
On my 2001 Blazer LT is the windshield wiper blade supposed to hang off the passenger side by two inches? Or do I need to get a shorter one? Or can it be adjusted for better contact??? It is really iritating . . . .
ktbass 03-12-2010 01:07 PM
my 2000 blazer does the same thing. kind of annoying, but they still work fine
JST4SHO 03-12-2010 02:40 PM
If you get the new fancy, "skeleton" free wiper blades and bend the pass side a little they work great and does hang. I forget which ones I have now, but I also like the stock a/c delco blades even though it does hang a bit it works best next to the newer style of blades.
wlorton 03-12-2010 03:57 PM
Mine hangs off like that as well and plus the tension in it is slightly crushing it
truesmack 03-12-2010 04:44 PM
Interesting, any recommendations on wipers out there, think i know the contoured ones you are talking about, just wasn't sure if they were worth the extra money.
wlorton 03-12-2010 05:10 PM
I bought the rainex ones just below the 20 dollar ones...
I like them... Work very well
jpmccr 03-12-2010 06:25 PM
The ones I currently have are the new RainX Lattitudes. Great blades for $17.99 each (Walmart). They come preformed and the driver's side is perfect. It is the passenger's side that is too long (?). I guess I can live with it if need be. I thought about getting a shorter one for that side but did not know how that would look while it was raining. Thoughts anyone????
truesmack 03-12-2010 08:20 PM
Doesn't is seem the passanger side always works better, so same size would be good i think. I keep looking at the blades but can't make up my mind which ones to try.
jeff618 05-01-2010 10:25 AM
NeoForms
1995-2005 Blazers take 20" wiper blades on both sides front. I'd highly recommend "Trico NeoForm Beam Blades" not only because they're the newer-style, frameless, one-piece wipers, but because its the only brand that comes in a 14" for the rear wiper so you can get a matched set all around. Oh...and they absolutely fricken rock too!! You can get them online for less than the rainx wipers...there's also a rebate on them through 5/15/2010 which makes them WAY cheaper than the rainx.
