-   -   01 blazer wipers stopped working (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/01-blazer-wipers-stopped-working-38256/)
jstutzman 12-19-2009 08:59 AM
i checked the fuse. When i unplug the 5 pt harness under the hood, the wiper motor jumps a little then agian dies. I have done a search and read thru a couple of posts and many think it is a resoldering issue with a control board. I do this stuff for a living so it is not an issue. Someone mentioned a wiper fix thread in the diy section that explains where the board breaks or needs fixed. I cant find it. Could someone fill me in on where the card is, what needs fixed or where the thread is that has that info. Thanks.
swartlkk 12-19-2009 09:52 AM
Fix for cold solders in the Wiper Motor
That should help. Check some of the link out in my signature for more helpful DIY threads.
jstutzman 12-19-2009 02:42 PM
well i thought i found the problem. It looked like it was a cold solder joint, but that did not fix the problem. What are the voltages on the pins connecting to the card, so i can make sure they are correct.
swartlkk 12-19-2009 03:02 PM
You would have to have someone back probe the wiring at the motor to get the respective voltages. I found wiring diagrams from two different sources which show resistors in the system, but do not state the resistance value.
http://i11.photobucket.com/albums/a1..._pulse_sch.gif
jstutzman 12-19-2009 03:07 PM
is it common for these modulator cards to go bad. Should i just replace it and do the motor next. Are the motors common to go out? I really need to get it fixed pretty quick.
swartlkk 12-19-2009 03:15 PM
The solder joints are the main thing that happens...
Can you help the wipers to get them going?
jstutzman 12-19-2009 03:20 PM
no, they are completly dead. when i pull on them, nothing happens
I have a problem in my other truck where they stick a little or stop and i can go out and tug on the wipers a little and they will start right up. With this one they are dead and nothing will get them working. One time when i plugged the harness into the pulse board the motor jumped about two inches and stopped
swartlkk 12-19-2009 03:25 PM
Sounds like the motor doesn't think it is back in its park position...
I would try removing the motor assembly and see it if works without it being hooked up to the rest of the wiper drive system
jstutzman 12-19-2009 03:27 PM
okay, ill give that a try. Any good writeups on how to pull that out?
