01 S10 Blazer fuel problem
Old Apr 5, 2009 | 03:31 PM
godabby's Avatar
godabby is on a distinguished road
Default 01 S10 Blazer fuel problem
Fuel and pressure at the throttle body. Added gas to the throttle body and it ran till the fuel burned up. Must be electrical? HEEEELP PLEASE!!!
Old Apr 5, 2009 | 04:33 PM
rriddle3's Avatar
No, probably fuel supply related otherwise the pump should have kept supplying it. What are the pressure readings at the test valve?
Try this post and see if it helps.
Old Apr 5, 2009 | 09:10 PM
godabby's Avatar
Check it tomorrow. Thanks! Let you know.
Old Apr 6, 2009 | 05:18 PM
godabby's Avatar
Just to let you know that is was the fuel pump. Only had 15 lbs pressure. Thanks for all the help. Appreciate it!
Old Apr 6, 2009 | 05:28 PM
rriddle3's Avatar
Glad you found the problem. If you're replacing the pump, do yourself a favor, spend the extra money and get AC/Delco. Also, don't let your tank get below ~1/4 full to keep from overheating the pump.
Old Apr 6, 2009 | 08:53 PM
LS Twins's Avatar
LS Twins is an unknown quantity at this point
We have a 2000 and a 2001-
I've replaced both of our's myself and yes be sure to buy a decent replacement-spend the $$$$ now or you'll end up doing it again soon.
I put a A/C Delco in the 2000 at $330.00 for the assm.(part's only) 1 year warr.
And I found a Bosch for the 2001 - cost was $420.00 for the assm. (part's only)Lifetime warr.
Plus your gas gauge which most likely does not work correctly will be accurate again!
Jesse31
Apr 6, 2015 03:23 PM
jonnymac12
Aug 7, 2013 12:54 AM
jfrust64
Jul 15, 2012 06:41 PM
suzonda
Aug 12, 2009 07:18 AM
bellijam
Jul 16, 2008 12:53 AM
