-   -   '02 Blazer heater fan only works on 2 and 3 (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/02-blazer-heater-fan-only-works-2-3-a-66781/)
diceman1000 01-09-2012 04:55 PM
but not 1 and 4??? any ideas guys???
warthogdriver 01-09-2012 05:03 PM
sounds like blower motor resistor...it mounts just to the right of the blower motor if your standing in front of truck.
if you do a search on it you may find a how to and some info to verify before buying a part.
diceman1000 01-09-2012 05:52 PM
thanks for the reply sir:)
pettyfog 01-09-2012 06:40 PM
Hi doesn't go through the resistor.
Check your underhood fuses, there's a 30a for just high speed. And a relay that's actuated in "4".
Not running in "1" would be the resistor
That or the speed switch is faulty
warthogdriver 01-09-2012 07:01 PM
Thanks for the correction...i learned soemthing on this one too.
:D
