02 Blazer post-heater core coolant issue, help!?
I just got done switching out the heater core in my 2002 Blazer ZR2, and am now trying to finish up and fill the coolant. I can't seem to get more than a gallon or maybe gallon and a half in. I tried starting it to try and get it to start circulating through the engine, but the temp came up high (~240 F) within 2 minutes or so and I had to shut it off. Also, there is no sign of heat but I sort of expect that since it doesn't seem to really be circulating anything. What could be the cause? I'm stumped as to why it won't take it?
Thanks! |
Did you flush the coolant system? Sounds like a circulation issue...
try flushing the heater core
its worth a try |
Vapor-lock in the heater? Try loosening the heater return hose, then running the engine until coolant flows from the hose.
Thanks for the input guys. I ended up pulling the return line off the heater core and connected the hose to the flush out fitting on the inlet to bleed the new core. I also parked the front end up the bank in front of my house to get the rad up as the highest point and this got tons of air out. I could hear the gurgling sound in the truck. All seems good now.
| All times are GMT -5. The time now is 04:46 AM. |
