1995 blazer
1995 blazer
okay i have a black 95 blazer and i pulled over yesterday set the hazzards on and then the switch broke. how do i get them to turn off? i pulled the #1 fuse. but then noticed had no break or blinker lights. i checked everything. i have the whole dash board in the back seat right now. looking at everything. and i was wondering what i should be looking for to get my hazzards to shut off but still have my turn signals. is there a wireing set up going to the switch? and where would it be located. im looking all under the stering colom and cant see a wire going to the hazzard button. and also dont know anything about eletrical problems.
thnak you
justin
thnak you
justin
Can you push on the hazard button with something to disengage it? All of the brake & turn functionality goes through that switch. If you can't get it to disengage, you either have to replace the switch itself (not sure if the PNs listed in the Tech Article DIY post on the subject work for a '95) or the entire multifunction switch.
