1995 blazer sometimes wont start?????
NEED HELP!! every couple days my 95' 4-door blazercranks over fine,but wont start. if i spray carb cleaner inthe intakeshe takes right off, runs good. checked fuel pressure with key on about 60, goes up a hair while cranking, and if i start it with carb cleaner drops to 50-58 while running.
7out of 10 times it starts and runs fine, noservice light on. dont know why the carb cleaner gets it to start?? any ideas whats wrong? |
RE: 1995 blazer sometimes wont start?????
did you check for good spark and when was the last time you changed the fuel filter??
i assumed the spark was fine, and i have not changed the filter.might be aneasy and cheap place to start.
I had virtually the same issue. 95 Blazer/130K. Replaced the fuel filter (Old one looked like it could have been the original) added some injector cleaner to the gas tank drove it on the highway for a while then let it idle for a couple of hours. It seems to be starting fine now...we'll see.
I also have the same vehicle as you. I have had the same problems as you. Can you smell gas when it is running? Are you getting bad mpg? If so I think it is your fuel pressure regutator. That iswhat mine was doing. There is a how to post on how to change it.
| All times are GMT -5. The time now is 02:38 PM. |
