1995 blazer won't start
Old Nov 10, 2013 | 03:53 PM
fenman00's Avatar
fenman00 is on a distinguished road
Default 1995 blazer won't start
Blazer had starter replaced 2 years ago, fuel pump comes on, all lights, bells, and gauges light up, rotor , plugs, plug wires, and distributor just replaced.. turn key over and no sound other than fuel pump kicking on. Any ideas.
Old Nov 10, 2013 | 03:55 PM
chris015's Avatar
no sound...is the engine turning over?
Old Nov 10, 2013 | 07:08 PM
spittybays
Guest
Posts: n/a
Check voltage at battery, need at least 11.5, clean battery terminals, follow heavy black wire from negative terminal to engine block. Make sure all are clean and tight.
The main idea is a simple bad electrical connection.
Old Nov 11, 2013 | 08:16 AM
fenman00's Avatar
no, the engine is not making a sound at all.
Old Nov 12, 2013 | 12:16 PM
tahwos's Avatar
tahwos is on a distinguished road
I'd go after the solenoid or maybe a bad ground.
Old Nov 12, 2013 | 12:34 PM
DesertStorm's Avatar
check the battery voltage like spitty was saying. also check the cable at the starter and make sure you are getting full voltage through the cable from the battery to the solenoid. if it has had excessive corrosion over time it will follow the wires inside the insulation
Old Nov 13, 2013 | 11:38 AM
fenman00's Avatar
Cool. Will try that and see what happens.
Sky
Feb 12, 2012 10:04 PM
wings4kites
Jul 10, 2010 07:28 PM
Rogue7
Jan 18, 2009 10:31 AM
VikezFan
Nov 17, 2008 09:13 AM
mjj
Nov 19, 2006 11:34 PM
