1995 ideling problem
#31
ok i can hear the leak just dont see it i will go out and look the whole system over and see if i can fine any leak and fix it then will see how it is
#32
ok i have check the whole exhaust system out and fixed the leak i found no change in the idling problem so i pulled the spark plugs out one at a time check gap and i did notice that other then carbon up bit they were all wet with gas i think
#33
Still idleing problems
Yesterday i checked all the plugs and gaps all good started it it idled fine till at operating temp then it died and hardly idled this morning i tried to start it it started but wont idle , and it is running rich i think from the black smoke that comes from the tail pipe what could be causing the problem
#34
Have you tested the MAP sensor? Search for "MAP+voltage+altitude" with an author of "swartlkk" and you should find the relevant results.
#35
i tryed looking for it could not find it does it explain how to test the MAP also
#37
thanks i will test it and see what happens
#38
i have tested the map it seems to be ok i was rechecking the fuel system and found a small fuel leak on a line it did not sell of fuel or drip but i did check and it was fuel would that mall leak cause all this problem ? I did not see the leak at first a friend found it while helping me
#39
I have fixed the fuel leak it spit a bit and died at first but then ran for 1 hr before dieing again it spit and sputtered then died and other ideas
xckid
10-15-2008 05:58 PM
kpiper
12-15-2007 06:28 PM
