1995 s10 loss power
Old 09-13-2019, 05:49 PM
Rjc's Avatar
Rjc
Rjc is offline
Rjc is on a distinguished road
Default 1995 s10 loss power
Hi new to site, driving my s 10 with 2.2 Monday and cannot run over 50 mph. Number 1 and 4 has no spark. I replaced coil and still same problem. Compression is good. I can smell gas probably from cyl not firing. Any one had same issue in the pass? Any help greatly appreciated
Old 09-13-2019, 09:01 PM
GeorgeLG's Avatar
GeorgeLG will become famous soon enough
How do you know that two cylinders have no spark?
Do you have any codes?
Have you changed anything recently?
George
Old 09-14-2019, 04:33 PM
Rjc's Avatar
Rjc
Rjc is offline
As its running I pulled plug wires and no engine change or spark out of 1 and 4 . If I pull 2 truck dies and if 3 is pulled engine changes. I've changed coil packs,wires and plug.
Old 09-14-2019, 04:35 PM
Rjc's Avatar
Rjc
Rjc is offline
When I had coil packs out. I turned key on to see if I get power to leads to coil. I get on both
Old 09-14-2019, 04:59 PM
GeorgeLG's Avatar
That tells you that those cylinders are not contributing. You do not know why yet. It can be spark, compression or fuel. On the cylinders that show no change in rpm when the plug wire is pulled, check and see if there is spark at the plug. On a cylinder that does show an rpm reduction, check and see if you have 1" of strong blue spark.
Have you done a compression test?
George
Old 09-14-2019, 06:25 PM
Rjc's Avatar
Rjc
Rjc is offline
No spark at 1 and 4 has did compression test and all cyl read 150
Old 09-14-2019, 06:28 PM
Rjc's Avatar
Rjc
Rjc is offline
Is there a circuit or fuseable link that 1 and 4 ties into? I did replace coil but no change
Old 09-14-2019, 06:31 PM
Rjc's Avatar
Rjc
Rjc is offline
I did hook a scan tool but no codes or check engine light
Old 09-14-2019, 11:45 PM
GeorgeLG's Avatar
Do you have 1" of strong blue spark at the plugs of the functioning cylinders?
George
Old 09-15-2019, 12:13 AM
GeorgeLG's Avatar
Also if you swap coil packs do the functioning cylinders change?
George
Quick Reply: 1995 s10 loss power
