-   -   1996 blazer 4x4 issue (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/1996-blazer-4x4-issue-25287/)
blazzerium 12-01-2008 12:35 PM
Hi guys,after some search on forum,I can't find.
My problem is that the 4x4 HI don't want engage since 2 days(last week it works fine and all last winter too!!).
the 4x4 LO works normaly.
when I push the 4x4 HI button while the vehicule is moving on the road,nothing happens.
whit the vehicule stopped,at neutral,when I push the 4x4 HI ,I heard a serie of 4-5 clicking noise and after nothing.
somebodys have clues about my problem?
Thank you guys!!
Blazzerium(96 blazzer 3 buttons switch)
lowe42 12-02-2008 08:53 PM
RE: 1996 blazer 4x4 issue
The good news is, its prob not the transfer case, cause it does work in 4 low. Your actuator may be starting to go(but normally 4X4 wouldnt work at all in that case) and there is also a switch underneath on the front end that may havve gone bad
blazzerium 12-03-2008 07:15 PM
thank you lowe42,
I did some search on the net and find someone who already have this problem.He said that he had disconnect the battery for one hour,and after 4x4 work fine.
I did the samething,and magic!:D my 4x4 hi engage normaly.
I think it's the transfer case transfert module in the dash who tripped.
I will see what happen in the next weeks,if the problem come back,I probably looking for change the module.
what do you think about that?
