1996 blazer abs light on no codes??????
Old Feb 28, 2013 | 03:50 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Is it coming up "no codes present" or is it saying unable to connect to abs module?
Old Feb 28, 2013 | 04:36 PM
Diaita's Avatar
If the light is on and there are indeed no codes, it may be an issue with your ECU.
'96 is a weird year when it comes to ABS as well, if memory serves there are parts that will only work on the '96.
I have the ABS modulator from my '96(couldn't bare to scrap it after I pulled it) you can have for the price of shipping if that turns out to be your problem
Old Feb 28, 2013 | 04:56 PM
Originally Posted by stangwheeler
...My blazer has no 4 x 4 buttons or floor shift it is all computer controlled...
Something isn't making sense here. Someone correct me if I'm wrong here, but I don't recall Auto Trac being an option on your 1996 Blazer. Just out of curiosity, on the rear of the transfer case there is a 2" round aluminum tag with red text: What is the model number of your transfer case? This link shows where the tag is located: The Jeep New Process / NVG 242 Transfer Case
EDIT: What is the 5th character in the VIN?
What is the 10th character in the VIN?
Old Feb 28, 2013 | 05:18 PM
Diaita's Avatar
There are a few early Auto-Trac Blazers out there. There used to be one at the local wreckers with a Borg Warner transfer case, that as nearly as i could tell was full time 4wd. NP3 is the RPO code in the glove box.
Old Feb 28, 2013 | 05:37 PM
Yup, NP3 RPO, just found it! AWD was an option in 1996. Single speed NV149 transfer case, very rare, but they are out there. It is not an "active" AWD system, it is an automatic "on demand" system. Oh well, that still doesn't answer the ABS issue. I'll do some research on that AWD system with ABS.
EDIT: Not sure if this link will work, but here's a flow chart: http://content.chiltonsonline.com/co...s/88459g20.pdf
Old Oct 23, 2017 | 02:33 PM
JohnO's Avatar
JohnO is on a distinguished road
did you ever get to the bottom of this problem ?
Old Oct 23, 2017 | 04:42 PM
Rusty Nuts's Avatar
The abs codes are automatically cleared every time the vehicle is turned off. Drive until the abs light comes on and scan the codes before turning the truck off. If you shut the truck off, plug in the scanner, then turn the key to run there won't be any codes present.
Old Oct 30, 2017 | 06:07 PM
JohnO's Avatar
Like you said when I switch the vehicle off the code clear, so I drove it until the light come on (very quickly, after few yards) and tried to read the codes with 2 different scanners, both connected with the vehicle but stated no dtc is stored, any idea what my next step should be ?? Thanks
Old Oct 30, 2017 | 06:35 PM
Rusty Nuts's Avatar
There are a couple different kelsey hayes abs modules depending on what year your blazer is. Determine which one you have and search you tube repair videos for that model number. It's common for those modules to have cold (bad) solder connections.
Old Oct 31, 2017 | 07:54 AM
JohnO's Avatar
okay thanks for the info, I’ll check that out, would it be better to get a second hand module and replace the one I have rather than repair it ? What do you think ? Also a friend noticed my brake lights weren’t working so could this be connected to my problem ? By the way I really appreciate your help here, thanks
