1996 blazer airbag repair
i've replaced the airbag and front sensors and am replacing the arming sensor from a vehicle not envolved in an air bag deployment, same year as mine. i have a code set ( the light is on ), i believe it set from the deployment of the air bag , what does it take to clear these codes, i have a FSM. what is required to do the job?
I would start by getting the code itself. It may be reporting a problem with one or more of the components you replaced or something that you may have overlooked. You'll need a full feature scan tool to access the airbag system & retrieve/clear the code. Only clear the code after writing down what it is and letting us know.
| All times are GMT -5. The time now is 01:27 AM. |
