-   -   1996 chevy blazer heater problems (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/1996-chevy-blazer-heater-problems-243/)
dawne fischer 12-19-2004 04:41 AM
we have tried everything, thermostate, heater core, sensors, nothing is working, any suggestions? please reply, we live in chicago, we need heat
jimmy91444 12-21-2004 12:16 AM
RE: 1996 chevy blazer heater problems
When your engine is warmed up doe's both heater hose get equaly hot? I had the same prob when i bought mine , and the hose from the engine to the heater core was somewhat hot but the one going to the radiator was almost cold.After replacing many parts like you did , I found out that the hole on the engine were the hose connect was almost block with residu. Leaving just a small amount of hot water going to the heater core. After cleaning out the hole i had all kind of heat ..... I ve got the 4.3 lt and the hose has a quick disconect to the engine. Might be a bit different on yours, hope this help.
