1999 blazer motor mount
I am lookin for instructions on how to change the left side motor mount on my 1999 4x4 blazer.. a start to finish list of instructions would be great.. also i would like an estimated time to do this ..................................
I'm in the same boat as you, started on it today and realized it'd be quite the task, from what I see you need to drop the front differential a bit and I'd like to find a way to do it without having to drop the whole thing or drain fluids.. Hopefully a response to this soon..
I just dropped front diff yesterday and you have pretty easy access to the motor mount on driver side, but that is a hell of a lot of work for a mount, book says you should be able to lift engine and get at it from the wheel well...from looking at it without diff I suppose it is possible. Passenger side looks like you need to remove cv axle bracket, but again book says you can do it just by lifting engine a bit. I am worried I only had 3 out of 4 screws on driver motor mount...opps
