-   -   1999LS Keyless died (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/1999ls-keyless-died-35735/)
KD5NRH Oct 11, 2009 02:37 PM
1999LS Keyless died
This morning my keyless entry fob quit working. When I got home, I tried the spare, and it wouldn't work either. Tried resync, no luck. Tried the programming mode, and the locks cycle when entering programming, but still no response to the remotes.
I pulled both remotes apart, checked batteries and cleaned the contacts.
Any thoughts? I'm guessing the problem is in the RKE module, since I doubt both remotes would die at the same time. Any good way to test it?
vetteandblazerman Oct 14, 2009 08:34 AM
Just had the same thing with my truck.Try this, open key fob and remove
battery,then press the lock and unlock buttons together for a few seconds.This has the effect of clearing the memory in the fob,almost like booting your pc.Worth a try,it worked for me.
mosca1 Oct 14, 2009 09:28 AM
My truck just did this last week. Thought it was the fob but checked it out at autozone and it worked. Lokking around to find out how to re-learn my fob and found this thread. Tried the reboot on the fob and it works! Thanks vett!
watchthis Oct 14, 2009 06:31 PM
I kinda have the same problem my remote only unlocks the driver door and the back glass. It wont lock anything. I even ordered a new remote and same thing.
