2 questions.
Old Jul 4, 2011 | 02:09 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Default 2 questions.
First question: so i replaced the plugs, wires, cap and rotor with all AC Delco, put in a high flow cat and my truck still shudders a little when i step on the gas from a start. so i still have to clean the MAF and see if that helps but if that doesn't help im stumped. any thoughts? thanks in advance.
Second Question: my front right CV joint has alot of oil or grease coming off of it is it normal? the left one has no grease coming out of at all. i dont know what could be leaking. heres a pic, a little hard to see but you can see that its all black and oil covered.
Old Jul 4, 2011 | 02:14 PM
rriddle3's Avatar
Originally Posted by 97cherryblazer
First question: so i replaced the plugs, wires, cap and rotor with all AC Delco, put in a high flow cat and my truck still shudders a little when i step on the gas from a start. so i still have to clean the MAF and see if that helps but if that doesn't help im stumped. any thoughts? thanks in advance...
Have you worked through the 96+ Fuel System Diagnosis?
Old Jul 4, 2011 | 02:27 PM
i had my fuel pressure tested a while ago before this was happening and it was fine, i should probably do it again. but i thought if your pressure was off it would cause other problems through out acceleration and not just a slight shudder when first accelerating, or can it cause both?
thank you for the reply
Old Jul 4, 2011 | 04:15 PM
bugs825's Avatar
bugs825 is on a distinguished road
Maybe a small piece of carbon stuck in the EGR??? I don't know much about the 97 because I have a 95.
Nathan
Old Jul 4, 2011 | 05:33 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
When was the last time the gas filter was changed??
Old Jul 4, 2011 | 06:15 PM
redneck44244's Avatar
redneck44244 is on a distinguished road
about your second question, mine looked the same way when my wheel seal was leaking for that wheel so if i was you id take a look at that wheel seal on your diff.
Old Jul 5, 2011 | 02:18 PM
bugs: i cleaned my EGR about a month ago, im trying to remember now if this started happening befor or after i cleaned it. i do remember i was having problems with it sticking when i was cleaning it. i should probably go check it again
2002xtreme: i replaced the fuel filter about 5-8k ago. i wouldnt think it was that but i suppose it could be, if i sucked some crap off the bottom of the tank.
Thanks for the replies! i got more to look into now.
------------------------------------------------ EDIT --------------------------------------------------------
redneck: i kinda thought it was a seal :/ did you fix yours yourself? or did you have someone else do it?
Last edited by rriddle3; Jul 5, 2011 at 02:56 PM. Reason: COMBINING CONSECUTIVE POSTS
Old Jul 5, 2011 | 07:03 PM
i did it myself, but im also a mechanic so ya.
Old Jul 5, 2011 | 09:12 PM
How har was it?
Old Jul 6, 2011 | 06:39 PM
thank god.. i found my hesitation problem. the tube that attaches to the middle of the air intake (right before the plenum) was disconnected. im not exactly sure what its for but it was off. there is still a very small hesitation so i think i have a small vacuum leak somewhere. im pretty sure i heard one around the distributor area but ill look for it some other time. thanks all for the replies
