-   -   2000 4.3l Fuel pressure Reg, P300 (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/2000-4-3l-fuel-pressure-reg-p300-19052/)
kirakitty 03-29-2008 11:59 AM
my daughters 2000 4.3 blazer has had an issue with the famous P300 random misfire. I have gone through a few things. cap rotor plugs, When I checked the plugs that have only about 2k miles on them, they were very carboned up. Other forums I have searched suggested the fuel pressure regulator. I got up the nerve to tackle this, It took some time and skin off the knuckles, but I accomplished the task. Now when
I tried to start it, it was like a hard lock of the motor. Turns out the cylinders have filled with fuel, and yhu cant compress fuel. I took the plugs out, disconnected the coil, unpluged the fuelpump relay and cranked the motor, blowing fuel out theplug holes.My question is: what would cause the fuel to fill the cylinder. Did I leave something disconected? forget a plug or something?
swartlkk 03-29-2008 12:28 PM
RE: 2000 4.3l Fuel pressure Reg, P300
Bad FPR. If you have fuel flooding the cylinders, the FPR is definitely shot.
