-   -   2000 Blazer Rear Gate release inop (https://blazerforum.com/forum/2nd-generation-s-series-1995-2005-tech-41/2000-blazer-rear-gate-release-inop-41667/)
drlivingston 03-04-2010 09:34 AM
I pressed the rear gate release button and something popped. Now, I hear the electrical release, but the latch will not disengage. I would appreciate some help on getting access to the latch or any information on it's repair. thanks
MTopper 03-04-2010 10:33 AM
Hey there, the new member area is to stop in and say hello... your question should go elsewhere
but... if you use the search button you'll find things like https://blazerforum.com/forum/showth...hatch+actuator
swartlkk 03-04-2010 10:48 AM
*Moving to 2nd Gen Tech*
Definitely check out the link posted above! That is the most likely cause.
If you would like, you can create a new welcome thread in the New Member Area.
ryanarmstrong 03-04-2010 12:41 PM
can u get the gate open if so take the screws out of the inside panel then take the plastic off to access the locks and latches take them out and clean the carp out of them use white lithium grease and spray all moving parts and put back in door then move on to locks do the same rembering how they came out and then last check the lock pins to see if they are loose or if the plastic clips are broken if not screw everything back up and close gate check if it will reopen. hope this helps later dude
Fozzy 03-04-2010 04:33 PM
In my sons blazer, the plastic "grabber/pusher" was broken in half and could not open the release latch. Removed the rear cover off the tailgate interior cover (the wrong way) and simply put on a new one. It snaps onto the plunger on the electric actuator.
Chevy will try to sell you the whole unit!
You can get them off Rock Auto or I have three of them left! I didn't know they came two to a pack.
MTopper 03-04-2010 05:50 PM
I did this exact fix last summer and only broke the plastic tab right by the lock. The little plastic on the actuator broke and was replaced with the Rock Auto piece for like 4 dollars shipped to my door. Works great and i have a spare in case it breaks again.. Probably my fault from not closing the tail gate properly.. You live and you learn..
I used that exact thread last summer, its saved in my favorites just in case
drlivingston 03-05-2010 08:54 AM
Waiting for the parts
I found (I hope) the parts and they have been shipped. Thanks for all your help in directions and links to other similar sites. My first visit to Blazer Form (Had the 2000 since it was new can you believe it?) I too have this site on my favorites.
rvaughn42 04-18-2010 02:19 PM
first time to use blazer forum so not sure if this is proper way to ask question. my back lift glass will not open. i think i found the answer to the problem but how do you remove interior cover on gate to get to accuator if glass wont open and gate wont drop
jjnemoiii 04-18-2010 08:14 PM
Follow link in post #2, directions are there.
Brian_D 01-09-2011 04:00 PM
Can you possibly link us to that part?
Thanks,
