2000 Bravada - sluggish/surging acceleration
2000 Bravada, approx 90,000 miles. Very sluggish acceleration, started out as an intermittent issue, but last day or 2 it's been constant. To the point now where I have to hold it to the floor to maintain 40mph on a flat road. Also, it wont hold a constant RPM under constant throttle - it's a cycle of cutting off and surging. Another thing I noticed, which may or may not mean anything - above 5000 rpm, the volt gauge drops quite a bit and the AC stops running cold.
Ran the codes, and got the following: P0101 P0131 P0143 P0151 P0300 Researched the codes and it appears it could be a myriad of issues from plugs/wires, to O2 and airflow sensors. Any input as to the most likely culprit(s) will be greatly appreciated. Thank you! |
how long ago did you do a tune up on your truck? did you use ac delco parts?
(Post 444329)
P0101 - Mass Air Flow System Performance
P0131 - HO2S Circuit Low Voltage Bank 1 Sensor 1 P0143 - HO2S Circuit Low Voltage Bank 1 Sensor 3 P0151 - HO2S Circuit Low Voltage Bank 2 Sensor 1 P030x - Random/Multiple Cylinder Misfire Detected I would look into the power & ground supply for the HO2S sensors from the PCM as defined in the wiring diagrams in the linked to diagnostic threads. A PCM ground issue could cause the MAF & HO2S sensor codes and general poor performance. Look over the diagnostic threads for common diagnostic points. |
i say do a decent tune up check the whole truck over make sure you use delco parts . let us know if that helped it run better
Originally Posted by swartlkk
(Post 444332)
Researched on here and found that the PCM is grounded to the firewall by the brake booster (G117). Checked that out and it's tight and clean as a whistle.
Anything else easy to check before I wave the surrender flag? |
